Secret to clean graphics?
Jack Morgan
on May 20, 2011 at 4:20:51 pm
Been on FCP for 4 months now and I am having trouble getting small graphics, (around 17 points for disclaimers), to read cleanly. Sometimes I have to move them slightly up or down to get them to read right. Anyone have any thoughts on this? Thanks, Jack
jmorgan
DeadLine Productions
Houston, Texas
Chris Tompkins
Re: Secret to clean graphics?
on May 20, 2011 at 10:41:31 pm
And your sequence settings are....?
Your footage came from...?
And your viewing this how...?
Chris Tompkins
Video Atlanta LLC
Cody Walters
on May 20, 2011 at 10:38:52 pm
Hi Jack. Nice to see someone from Houston here on the forms. I usually use Photoshop to size my graphics appropriately within the frame I will be working with in Final Cut. In my experience, small graphics has been a pain. A graphic designer gives you this large image and you only need it 25% percent of the size. It's hard to give you specific advice because I don't know what you are dealing with (if you have vector files, PNG, JPEG. The best quality you will get is receiving the graphic in vector, size it appropriately in Photoshop, and use that in Final Cut.
Can you give some specifics about the type of image and your image sequence?
Cody Walters
JW Studio LLC
Houston Video Production
Houston Wedding Videos
Final Cut Studio 3
Adobe CS5 Master Suite
Panasonic HVX-200
Canon 7D
Greg Ball
on May 20, 2011 at 10:50:56 pm
Jack, It's best to have your graphics resting on an even scan line. Go into your motion and make sure that you X and Y are even numbers. Also avoid DV codecs for better graphics
Roli Rivelino
on May 21, 2011 at 7:40:56 am
I've just been given a link to this article on imported images into FCP and it was like someone opening up the blinds in a previously darkened room, enjoy... http://www.larryjordan.biz/articles/lj_grfx_look.html
http://www.rolirivelino.com/
System
Mac Pro 2.8Gb quad core
8Gb RAM
1x 320Gb 7200 hardrive
1x 1Tb 7200 hardrive
Nvidia Geforce 8800 512mb Graphics card
1x 1Tb external WD 'My Book' eSata
Equipment
Panasonic AG-HVX 200
Firestore FS-100
Rafael Amador
on May 21, 2011 at 9:16:54 am
Hi Jack,
When setting graphics, make sure that the x/y center values are integers.
If you are working interlaced, make sure that the "y" values are always even numbers.
rafael
http://www.nagavideo.com
Jack Morgan
on May 23, 2011 at 3:24:30 pm
Good advice all, Thank you for the responses. The key seems to lie in doing the graphics in Photoshop as the problematic stuff is in the smaller type that I type in text or Boris... Thanks, Jack
jmorgan
Houston, Texas
