Kodak Zi8 - Workflow Impossible
Bill Brownstein
on May 6, 2011 at 6:06:08 pm
I've tried just about everything to work with these files.
Obviously the files need to be first transcoded as they are created in H.264
Compressor crashes every time I try to add just one of the files.
So I used Quicktime Pro 7 to create ProRes files. That worked.
When I bring the files into FCP to work with them, that's when strange things happen.
I make edits with the files and construct a sequence. But when I export, I get a combination of problems. Sometimes the exported sequence will be just black; no audio and no images, just black. Or, it will export aspects of the video that was not even within my In/Out points. Just random footage.
Anybody else have problems with this? All the Zi8 files were shot in 29.97 and will ultimately be part of a project that was shot in 23.97 so they will need to be converted to that frame rate in the end. Somehow.
Rafael Amador
Re: Kodak Zi8 - Workflow Impossible
on May 6, 2011 at 6:41:29 pm
Have you tried this?:
http://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
rafael
http://www.nagavideo.com
Bill Brownstein
on May 6, 2011 at 6:51:32 pm
Yep, Log and Transfer doesn't work. It only works for Canon H.264 stuff because there's a specific plug-in for it.
Rafael Amador
on May 6, 2011 at 7:16:11 pm
Have you tried MPGStreamclip?
rafael
Bill Brownstein
on May 6, 2011 at 11:20:56 pm
Yeah, it creates successful ProRes files as well. But the problem occurs once I bring these files into FCP and start to edit and export them.
