transforming in to video
Vasja Mihelcic
on Apr 27, 2011 at 1:57:17 pm
Hello,
I,ve got an animation/graphic in tga extension, many clips-frames when i putt on timeline...how does the fcp transform this clips-frames(tga)in video? i hope i was understandable?
thx for your help...
fcp studio version
i7 mac
Mark Suszko
Re: transforming in to video
on Apr 27, 2011 at 3:39:35 pm
Hello, welcome. This is an easy thing to do.
Keep your .tga files in one folder, and it is important that the file names be sequential, and to have the same mumber of digit spaces to increment all across the name, for example: "subject0000.tga", "subject0001.tga", etc. This keeps individual frames from getting put in the wrong order later.
I go to my FCP user prefernces, and set the default duration of imported stills to one frame. Then I create a new bin in the project, drag the folder of .tga's into that bin, do a select> all, drag that to my timeline, done. From there I can also render out a self-contained .mov file if needed.
I'm told you can also use a function in quicktime pro for exporting image sequences as .mov files.
Vasja Mihelcic
on Apr 27, 2011 at 11:37:25 pm
thx easy as cake....:)
