How do I determine the resolution of a video clip?
Zeno Pierre
on Apr 20, 2011 at 8:04:42 pm
I know this is a dumb question, but I've been fighting with this for some time now. I created a video at a size that says 720x480.
Is 720x480 considered the resolution?
Greg Baldi
Re: How do I determine the resolution of a video clip?
on Apr 20, 2011 at 8:11:45 pm
Yes. 720 x480 is the amount of lines of resolution you have in that box. That resolution is also known as Standard Definition, SD, or 4x3.
-Greg Baldi
Post Production Editor
Jeff Greenberg
on Apr 22, 2011 at 8:29:27 pm
Yes, but keep in mind that the actual pixels aren't square. On a computer, it'd be closer to 640x480
I can hear you go 'Wha????"
Remember legos? Well, video uses legos that aren't square - they're a bit tall. If you had 720 (the width) skinny legos next to 720 wider legos, you'd still have 720 wide - but the wider ones would be measured longer. In other words, the dots aren't square, but are skinny and tall.
FCP and every other editorial tool accounts for this - and in HD everything is square and matches the size you see on a computer (mostly.)
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
Zeno Pierre
on Apr 22, 2011 at 11:12:57 pm
Thanks, Jeff, that'll help me to remember.
