Problem with MXF file transfer
matt johnson
on Apr 20, 2011 at 4:52:30 am
I currently shot a live event for a documentary I am doing. I used the hvx200 and copied the mxf files (contents and lastclip.txt) to a hard drive and returned the p2 cards to my school. Upon attempting to log and transfer the mxf files into FCP, I find that only a few of them work and the rest get to the end and then come up with a red stop sign with an exclamation point. They are not transferring correctly. I CAN play them all in the preview window, however. I am having trouble finding advice about this. I am in need of a quick solution to this problem. Please help!
Shane Ross
Re: Problem with MXF file transfer
on Apr 20, 2011 at 7:45:45 pm
in the P2 Import the P2 Browser, there is a little sprocket drop down menu. Click on that and choose PREFERENCES. Uncheck REMOVE PULLDOWN and then try importing again.
© 2018 All Rights Reserved
