Renders look worse than Pics at same size?
Andrew Harman
on Mar 24, 2011 at 12:02:56 am
I have made the slideshow from stills. Made them all 1920x1080 pixels - so all images the same. it is made up of real photos and architectural renders. Again, all the same size.
Weird thing is, the renders, especially on the diagonal angles appear semi bitmapped where the photos, all look great.
Why the difference?
Thanks All
Zane Barker
Re: Renders look worse than Pics at same size?
on Mar 24, 2011 at 12:27:53 am
What are your time line settings?
**Hindsight is always 1080p**
Jeff Greenberg
on Mar 24, 2011 at 4:20:07 pm
What Zane is alluding to, is that your timeline codec will compress your stills when rendered. Depending on the timeline settings, they could look better. Try switching the timeline to ProRes and see if it takes care of the artifacts (at all.)
Also, you should really evaluate the quality on a broadcast monitor, not your FCP preview screen (or Digital Cinema Desktop, unless it's set to Raw)
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
Chris Tompkins
on Mar 25, 2011 at 12:02:44 pm
What format are the Drawing in?
Thin lines are usually a challenge.
Chris Tompkins
Video Atlanta LLC
Andrew Harman
on Apr 4, 2011 at 1:04:44 am
The Renders are supplied as hi-res Tiffs. we have used this renders (they are effectively pictures as are photo real) in the glossy brochures.
I realised that i posted this in the FCP section. I am using a different program to generate the video file slideshow so there is not timeline to mention.
Thanks All
Chris Tompkins
on Apr 4, 2011 at 11:16:19 am
Sometimes I find hi-rez files don't do as well. Can you set the DPI of the stills down to 72 b/4 import and see how they look?
What codec is your sequence?
Chris Tompkins
Video Atlanta LLC
Chris Tompkins
on Apr 4, 2011 at 11:22:42 am
Walter has psoted a tutorial here on the cow on working with stills, don't know if it relates to your issue a whole lot but might be worth taking a look @ if you haven't:
http://forums.creativecow.net/readpost/200/892118
Chris Tompkins
Video Atlanta LLC
Andrew Harman
on Apr 5, 2011 at 11:27:52 pm
i had made all the pics 72 dpi and 1980x1020 before importing.
Thanks All
Andrew Harman
on Apr 5, 2011 at 11:29:46 pm
codec is H.264
Thanks All
Rafael Amador
on Apr 4, 2011 at 12:40:35 pm
[Andrew Harman] "The Renders are supplied as hi-res Tiffs. we have used this renders (they are effectively pictures as are photo real) in the glossy brochures."
Which is your Sequence codec and your Render setting?
Set Prores and "Render in High Precision" and "Render Motion Effects: BEST".
rafael
http://www.nagavideo.com
Chris Tompkins
on Apr 5, 2011 at 11:31:40 pm
NEVER edit in H.264
Did you change your settings to ProRes as suggested here?
Chris Tompkins
Video Atlanta LLC
Andrew Harman
on Apr 5, 2011 at 11:33:19 pm
There is no pro-res setting in this program.
Thanks All
Chris Tompkins
on Apr 5, 2011 at 11:35:43 pm
You posted your question in a FCP forum.
Chris Tompkins
Video Atlanta LLC
Andrew Harman
on Apr 5, 2011 at 11:37:41 pm
Yes, i stated above that i realised in the wrong section.
Thanks All
Zane Barker
on Apr 5, 2011 at 11:39:33 pm
[Andrew Harman] "The Renders are supplied as hi-res Tiffs."
Tiffs are image files so they cannot be rendered video files.
Andrew Harman
on Apr 5, 2011 at 11:44:58 pm
that is correct. the tiffs are converted to jpg's and then used to make the slideshow which was output as a video file.
Thanks All
Zane Barker
on Apr 5, 2011 at 11:37:45 pm
[Chris Tompkins] "Did you change your settings to ProRes as suggested here?"
Chris, Andrew said this earlier.
[Andrew Harman] "I realised that i posted this in the FCP section. I am using a different program to generate the video"
Considering he is NOT using FCP and has NOT said what program he is using.
NOBODY here can help him because we don't know what program he is using. And even if we did know there is a good chance we may not be able to help because we may not know that program.
Why the question was even posted on a FCP forum I have no Idea.
