adj a range of clips w Audio Mixer?
Paul Dougherty
on Mar 22, 2011 at 9:16:37 pm
Is there a way (as one would do with an Avid) set a range with in & out marks in a seq then set a level or pan (or plus/minus adjust) in the Audio Mixer to change a range of clips all at once?
Paul
Jeff Greenberg
Re: adj a range of clips w Audio Mixer?
on Mar 22, 2011 at 10:07:09 pm
You could select the clips (sorry - no in/out here) and use the Modify - Adjust Levels (and make sure it's relative).
Same concept - you could also use the Control [ ] and Control - = (for +-1 and +-3db)
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
