Multiclip switchout
Stan Pietrusik
Multiclip switchout
on Mar 22, 2011 at 3:39:15 am
hi...I have a project that I'm working on and I'd like to switch out the existing multiclip in the sequence with a modified new multiclip but I'd like to keep all the existing cuts...is this possible?
if not, then am I able to take my existing multiclip that is in the sequence and go into it and adjust one of the 4 video clips forward about a second as it has come out of synch with the main audio track? (the other 3 clips in the project are in synch, its just the one that is abit out)
thanks!
Jeff Greenberg
Re: Multiclip switchout
on Mar 22, 2011 at 10:19:39 pm
[Stan Pietrusik] "'d like to switch out the existing multiclip in the sequence with a modified new multiclip but I'd like to keep all the existing cuts...is this possible?"
Dicey - but worth a try. If it's the same exact length and same exact sync point, you could rename the new QuickTime to match the old.
Then just relink to the new QuickTime.
[Stan Pietrusik] "if not, then am I able to take my existing multiclip that is in the sequence and go into it and adjust one of the 4 video clips forward about a second as it has come out of synch with the main audio track?"
Yes, but I think you need to adjust this before the cuts, not after. No idea what will happen.
Hold down Control and shift and you can drag left/right and offset your mis-sync'd angle.
If the angle is drifting out of sync over time, this will not fix it.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
