performance issues
Micael Naser
performance issues
on Mar 21, 2011 at 7:24:02 pm
Hi, i recently started to use Final Cut 4 to edit and post some clips on Youtube.
I'm using a Mac G5 dual 2ghz with the only addition of 3gb of ram to the standard issue, i know that it's old but served me fine until now...
My issue is that when i try to export a file, let's say 1-2 min clip takes at least 1 hour!
When i use other software to just compress a full length movie takes 20min, see the huge difference?
I appreciate for the help.
Chris Tompkins
Re: performance issues
on Mar 21, 2011 at 7:56:42 pm
Do you export using "Current Settings" ?
What are your sequence settings?
Chris Tompkins
Video Atlanta LLC
Micael Naser
on Mar 21, 2011 at 8:12:07 pm
Hi! well, i'm just editing video from my iphone 4 at 720p adding some PiP and color correction to make a Vlog.
If i try to export using quick time movie, takes 30min and 500mb file, when i use the other setting i use mpeg-4 and then H.264 and keep the same 720p (because are the only formats i got a bit of knowledge of) takes at least 1h and with crappy results.
To me..i don't mind the video codec as far as it's good and below 50mb/1min.
Zane Barker
on Mar 21, 2011 at 9:28:33 pm
Video files from iPhone are h.264 and h.264 is NOT an editing codec.
You need to convert to a proper editing codec before bringing the files into FCP.
**Hindsight is always 1080p**
