working with both 1920 x 1080 and 720 x 576
Adam Heayberd
on Mar 8, 2011 at 5:44:15 pm
I have clips coming in which are off different sizes. Which clips should I use to setup my time line, the 1920 x 1080 clips and then let the 720 one come in and just adjust or is it better to compress the 1920 footage down to a 720 size?
Does this even make sense?!?!
Adam
Editor & Self Shooter in the UK
http://www.aheayberd.tumblr.com
http://www.twitter.com/adamheayberd
Andrew Rendell
Re: working with both 1920 x 1080 and 720 x 576
on Mar 8, 2011 at 5:57:02 pm
Depends on what you want to end up with. If you want to end up with an SD output to tape, file or DVD, you might as well cut it as SD. Will you ever need a HD version? If that's a yes or you think it's very likely, then go HD...
