Strange outlines!!
Joel Thiessen
Strange outlines!!
on Mar 3, 2011 at 11:18:04 pm
Hi, i've just noticed a strange outline effect that has been going on in my time line. It seems that the border of some clips make a black edge, which is emphasized when the edge if feathered! Also in the same sequence when I move a text it creates another (but different) outline around the text.
My sequence setting is H.264 if that makes a difference.
I need some advice!!
Notice the black line just to the left of her?
This is the same object with a feathered edge.
And the weird text thing!
Chris Tompkins
Re: Strange outlines!!
on Mar 3, 2011 at 11:33:05 pm
Crop it out.
Chris Tompkins
Video Atlanta LLC
Joel Thiessen
on Mar 4, 2011 at 6:12:26 am
It wont work to crop it out. The black line is the cropped image. If you crop it the line just moves with the edge of the crop.
Joel Thiessen
on Mar 4, 2011 at 6:57:16 am
It seems like it affects White Color Solids more than others...
Rafael Amador
on Mar 4, 2011 at 2:01:26 pm
H264 shouldn't imported to FC, but if its works is OK.
What you shouldn't do is to render H264 stuff, with all these effects on top, on a H264 time-line.
Change the sequence codec to Prores or whatever.
rafael
http://www.nagavideo.com
Joel Thiessen
on Mar 4, 2011 at 6:58:05 pm
So when editing a clip that is in H.264 what are the ideal sequence and output settings?
Chris Tompkins
on Mar 4, 2011 at 7:14:42 pm
Don't edit H.264 files.
Convert before import or Transcode on ingest.
.h264 is an acquisition and delivery format only and not made for editing.
Chris Tompkins
Video Atlanta LLC
Joel Thiessen
on Mar 4, 2011 at 7:20:30 pm
So if I am given H.264 files i should convert them totally before they hit the timeline? What is the fastest way of going about this?
John VonMutius
on Mar 4, 2011 at 8:46:57 pm
Batch transcode using Compressor. Use one of the ProRes presets (422 or 422 LT, audio pass-through), save yourself some trouble. You can do a quick-and-dirty cut in h.264, but as you can see working with it in any depth is just impossible. And don't bother trying to use ProRes HQ - even ProRes 422 is usually overkill, because you're not going to add quality to h.264, it is what it is.
Exploring the pitfalls of the 5D workflow. The many, many pitfalls...
Joel Thiessen
on Mar 4, 2011 at 8:55:04 pm
Ah guys! Thanks so much, this is a breakthrough!
You learn something everyday!
