Getting a clean render from 800x600 original
Dane Udenberg
on Feb 25, 2011 at 3:16:20 pm
I am using an RGB2USB box to record the output of a computer's 800x600 screen to video clips using MPEG 4.2. I am bringing the resulting clips (which look really nice) into Final Cut Express, where I'm editing them and adding some titles.
Now, I need to render the edited clips to a format that can be burned to DVDs for training purposes. However the output looks nasty. Text is blurred and "doubled" looking. I'm sure this it's just a matter of choosing the right output format, but so far I haven't stumbled across one that looks OK.
Given what I am presently using, what's the best thing I can do to capture/edit/render/save good clean video for DVD?
Rafael Amador
Re: Getting a clean render from 800x600 original
on Feb 26, 2011 at 1:55:15 am
Hi dane,
The issue here is the size.
DVDs only supports 720x480 (NTSC) or 720x576 (PAL).
You need to stick with one of them.
rafael
http://www.nagavideo.com
Dane Udenberg
on Feb 26, 2011 at 1:33:17 pm
Thanks Rafael. Since the computer I'm capturing is 800x600, I assume my only recourse is to crop the screen size in the clips. Does that sound correct?
Rafael Amador
on Feb 26, 2011 at 4:38:59 pm
I imagine you are working with Squared pixels.
I guess that you will need to resize and crop.
rafael
