Import photoshop pictures without changing the format/document size
Mikkel Andersen
on Feb 14, 2011 at 3:20:54 pm
I want to set up a photoshop document, so i can line up a series of pictures and then import the 3 separate
pictures to Final Cut Pro 7. The problem is every time i import my pictures, the format changes in Final Cut. What am i doing wrong? I have tried to change the pixel aspect ratio in my Photoshop document, but without luck and i have tried to remove attributes (distort) in Final Cut, but also without luck......
Here is some screenshots of my Final Cut document and my Photoshop document:
http://img198.imageshack.us/i/finalcutq.png/
http://img809.imageshack.us/i/photoshopm.png/
http://img218.imageshack.us/i/examplej.jpg
Thank you for your time..
Best
Mikkel
Andrew Rendell
Re: Import photoshop pictures without changing the format/document size
on Feb 14, 2011 at 4:07:41 pm
The first thing I spotted is that in the first screen shot you've got a frame size for 720p but below it the pixel aspect ratio is PAL CCIR601 which is non-square pixels. That might not be the only issue, but it's not going to help - it should be square.
Zane Barker
on Feb 14, 2011 at 5:11:51 pm
Why are you using a "custom" setup in FCP? Use one of the photoshop presets so that everything is set up properly.
**Hindsight is always 1080p**
