Render B4 Export
peter tours
Render B4 Export
on Feb 2, 2011 at 8:38:49 pm
When exporting a sequence with unrendered fx, must you render first then export, or does export take care of it all?
Peter Tours
TnT Video Services, Inc.
Fort Lauderdale, FL
peter tours
Re: Render B4 Export
on Feb 2, 2011 at 8:43:48 pm
Or for that matter before sending it to Compressor, it it is different...
Peter Tours
Fort Lauderdale, FL
Todd Gillespie
on Feb 2, 2011 at 8:51:12 pm
Hi Peter,
No, you don't need to render to export or send to compressor. FCP will redraw each frame of as it's exporting or compressing. Only when exporting to tape do you need to render all.
I don't worry about render everything before exporting, I only render for playback or to verify effects.
Good Luck,
Todd at UCSB
Television Production
Tom Wolsky
on Feb 2, 2011 at 9:23:06 pm
Except in a few circumstances it's generally a good idea to render before exporting. Apple recommends you render all media to full. Unrendered effects that slow down the export process can cause issues such as corrupted frames. It's also a good idea to mixdown the audio before exporting.
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP7," "Basic Training for FCS" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
