Edit trim window FCP6.0.5
Alan Lacey
on Feb 2, 2011 at 6:41:09 pm
I've not used the edit trim window in FCP much before.
When it's open the cursor changes from roll to Lripple to Rripple when moved over the Lclip and Rclip windows. It doesn't do anything though when dragged. Is this correct? I was expection the edit position to change when dragged.
Alan
FlashXDR,XDcamHD,XDcamEX,D9 etc
FCS,AE,Combustion,LiquidSilver,Vegas,Edius,
G5,MBP,Vista64,XP
Tom Wolsky
Re: Edit trim window FCP6.0.5
on Feb 2, 2011 at 7:36:35 pm
You could drag the in or out points in the window, but the trim window is not really designed for dragging. The timeline is. You can use bracket keys to ripple or roll an edit, or comma and period. You can use JKL to ripple or roll dynamically. The trim edit window is a complex tool, too much to explain in a forum message. I really suggest you read the section in the manual or some other instruction tool on using this window.
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP7," "Basic Training for FCS" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
Alan Lacey
on Feb 3, 2011 at 12:53:31 pm
Thanks for the info Tom, I'm don't use FCP a great deal and I was expecting the roll/ripple to work in the viewer windows as it does in Edius. I wonder what the point is then of the cursor changing?
Kindest regards Alan
G5,MBP,Vista64,XP
Tom Wolsky
on Feb 3, 2011 at 1:51:03 pm
To tell you which function you're in, ripple or roll, and which side you're effecting.
All the best,
Tom
