motion tab missing?
Emmet Reddy
motion tab missing?
on Feb 2, 2011 at 12:50:20 pm
In my effects tab my MOTION tab has disappeared? so i cant move a clip around the screen.
I have edited the same clip into the timeline again and the motion tap reappears?
Any ideas?
Thanks Emmet
Anthony Bari Jr.
Re: motion tab missing?
on Feb 2, 2011 at 11:03:15 pm
Sounds Silly, but did you try and show all window command? Usually the set to one of your F keys.
If you don't use the F keys for FCP. Otherwise, just use the touchpad>4 fingers swipedown
It can hidden behind the Viewer or Canvas windows. If none of that reveals, the mighty motion tab, then close the viewer window, and hit Control+U (standard layout)
You can always go under the window menu, or CMD+1 to bring up the viewer.
Hope that helps.
*Production*Post-Production*
Apple Certified Instructor (Final Cut Pro 7)
"Semper Fi USMC"
