Must render audio on most of timeline each time I make a cut...
Chris Fera
on Jan 31, 2011 at 7:20:50 am
Hi there,
I am having an issue with the sound on my timeline. All the sequences that have more sound tracks (effect, music, room tone...) must be rendered each time I perform a cut on the timeline or simply drag and move the scene to a different position. I have two external western digital hard drives with 400 firewire connection... any way to avoid this? Thank you.
Chris Tompkins
Re: Must render audio on most of timeline each time I make a cut...
on Jan 31, 2011 at 2:25:33 pm
What format is your audio? Not using mp3 are you?
Make sure you're using Broadcast wav's or 48k aif's
Also check your real-time settings for audio:
Chris Tompkins
Video Atlanta LLC
Chris Fera
on Jan 31, 2011 at 7:18:50 pm
Hi guys, it was my real time audio tracks... it was set at 8. I changed it at 16 and it's all good now. Of course I am not using mp3 ;) only wav thanks a lot!
Matthew Miller
on Feb 10, 2011 at 3:55:08 am
few, thnx
Zane Barker
on Jan 31, 2011 at 3:48:41 pm
What you are putting in your timeline does not match your timeline settings.
**Hindsight is always 1080p**
