frame skipping in QT Mov.
george sloan
on Jan 29, 2011 at 1:39:38 am
Just saved a 3o minute program QT Movie(with compression markers) everything looks great except for occasionally skipping a frame or 2. Will this correct when I export to compressor? What could be happening?
George Sloan .. FCP7,Leopard, Dual Core, Mac Pro 2.66mhz final output to
ProRes>QTM>Compressor>SD-DVD down convert>forDVDF distribution/Broadcast
Jeff Greenberg
Re: frame skipping in QT Mov.
on Jan 29, 2011 at 7:35:39 pm
Yes, it'll be fine.
QuickTime is a playback engine, but it's also a container. There are a number of codecs that aren't optimized for playback through QuickTime, but QuickTime still holds all the frames. When it gets to compressor, it'll access each frame for further compression.
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos
Compressor Essentials
george sloan
on Jan 29, 2011 at 10:22:44 pm
Jeff G,
I worked until 3AM last night trying to figure that out!
I was beginning to think I had asked asked a dumb question.
You are my Hero. Need more like you.
George Sloan Productions
"Music Mountain" Channel 4 Windstream Cable TV
Cannon Xh A1 1080i>FCP7/ProRes>SD DVD>For Delivery to Broadcast and DVD distribution
© 2018 All Rights Reserved
