Exporting to camera
Cyndy Green
Exporting to camera
on Jan 25, 2011 at 6:35:31 pm
For some reason, whenever I attempt to export an edited project from either iMovie 6, 9 or Final Cut Express, the program(s) go into a very lengthy setup mode, which can last up to several hours. Kind of like the "writing video/audio" message you get with Final Cut before you can print to video. This only started up in the past three months and it extremely frustrating...my camera generally goes to sleep before the import begins.
I've check all camera settings and have had to resort to putting the camera into pause/record, then playing back the video, then recording. Sometimes even this doesn't work.
What could be causing this? Thanks in advance.
Rafael Amador
Re: Exporting to camera
on Jan 25, 2011 at 7:10:11 pm
Hi Cindy,
With that info is difficult to guess what going on with your computer.
What kind of footage are you working with?
Which setting?
Effects?
This doesn't sounds like any camera issue to me.
Have a look to the Activity Monitor while FC is "thinking".
That may gives you an idea if FC is rendering.
rafael
http://www.nagavideo.com
Cyndy Green
on Jan 29, 2011 at 7:11:10 pm
Thanks for the reply Rafael. I'm using both HD and SD and iMovie 6, 9, and Final Cut Express 4. Same issue with all...beginning to think it is a computer issue.
