why would my 16:9 hd sequence in fcp export as 4:3 when uncompressed
Allison Alford
on Jan 21, 2011 at 1:53:04 am
I exported a fcp file using qt movie export, uncompressed 8-bit. The file had the sequence settings 1280x720 hdtv 720p (16:9) and once exported it became 4:3.
does anyone know how i can avoid this? i shot the video with a canon t1i in hd format so i thought the original footage was also 16:9.
hope my question makes sense.
thanks!
Thomas Morter-Laing
Re: why would my 16:9 hd sequence in fcp export as 4:3 when uncompressed
on Jan 21, 2011 at 7:31:31 am
Why are you exporting as uncompressed HD? Have you checked the size settings in the export window? Could be to do with that
:D
Tom Morter-Laing
Freelance Editor
Certified Apple Product Proffessional, 2010
http://www.depictproductions.co.uk
Sony Z5, with Rode NTG2.
iMac 27" intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
Allison Alford
on Jan 21, 2011 at 4:15:00 pm
thanks thomas.
the reason i exported uncompressed is that i wanted a high quality video and had read that this was the way to do it. i'm working with a 5:14 minute video loop so when uncompressed it's 6.6 gb. but then in order to burn the dvd i put it into compressor and then into dvd studio pro and was able to adjust the display size in studio pro to 16:9. when it played in a dvd player the quality looked perfect but at times it was horribly pixelated.
unfortunately, when exporting i don't have the option to export using compressor. i'm using fcp 7 but it doesn't appear as an option.
any suggestions on how i can get high quality video to run on a dvd player for several hours without issue?
much appreciated!
Rafael Amador
on Jan 21, 2011 at 9:01:11 am
[Allison Alford] "The file had the sequence settings 1280x720 hdtv 720p (16:9) and once exported it became 4:3."
1280x720 is OK if the pixels are SQUARED.
Have a look to the QT Info window, or import the movie back to FC and have a look to the clips settings.
rafael
http://www.nagavideo.com
Allison Alford
on Jan 21, 2011 at 4:17:36 pm
Thanks Rafael.
And yes the pixels are squared. If 1280x720 is just OK are there better options that you would suggest for maintaining high quality video, 16:9? it's a 5:14 min video shot in HD.
Rafael Amador
on Jan 21, 2011 at 6:18:25 pm
At 1280x720 square pixels the image must shows perfectly 16x9 in QT Player.
If is not like that, open the Clip Properties and try the adjust the size on display.
rafael
