Importing: visual problems
annette lathbridge
on Jan 15, 2011 at 4:15:13 pm
Hello
I received footage from a film maker that was shot using an XD HD Camera. It's a quick time file,I've updated my quick time software. When I imported it into final cut, I could only hear the sound but could not see the images. can anyone help me?
annette lathbridge
Jeff Greenberg
Re: Importing: visual problems
on Jan 15, 2011 at 5:57:21 pm
Can it be opened in QuickTime? It sounds like you don't have the codec installed. What was the specific camera?
Best,
Jeff G
annette lathbridge
on Jan 19, 2011 at 8:12:35 am
Hi Jeff
Thanks for responding the file can be opened in quick time but I only hear the sounds and can't see the image whenever it's played. The camera used was a Sony XD Cam EX1
Annette
Jeff Greenberg
on Jan 19, 2011 at 2:24:51 pm
Annette, I know it's a silly question: Do you have FCP installed on the system you're looking at? If you don't have the proapps, the XDCAM codecs aren't on the system.
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com
annette lathbridge
on Jan 20, 2011 at 3:49:09 pm
Hi Jeff,
Iv'e got final cut express installed but not final cut pro. Would I need to install final cut pro in order to see the footage?
Annette
Jeff Greenberg
on Jan 20, 2011 at 5:37:51 pm
Yup, that's the problem. The codec requires a license and FCE doesn't have the license - FCP does.
You could find someone to convert it for you to FCP, you could try recording it into a camera/deck that FCE does communicate with (such as HDV).
Best,
Jeff G
annette lathbridge
on Jan 21, 2011 at 2:16:16 pm
Hi Jeff
Ok thanks alot for your help
Annette
Anthony Bari Jr.
on Jan 16, 2011 at 11:35:06 pm
Do you have the RAW clips from a card? Just QT movies stripped from the original source?
Helps to download the Freeware Sony has:
http://www.sony.ca/xdcamex/support.htm
Hope that helps you.
Jeff is right, make sure you have the Codec installed on your machine.
*Production*Post-Production*
Apple Certified Instructor (Final Cut Pro 7)
"Semper Fi USMC"
