Which DVCPRO HD setting to choose to convert a .mov file
Jo Colley
on Dec 9, 2010 at 10:21:18 am
Hello,
I have a .mov file on USB which I want to edit on FCP5. I have been advised to edit it using DVCPRO HD but I don't know which of the settings to use... 720p30... 1080p30... I'm completely lost.
The footage was initially recorded on an SD camera as a progressive format, and apparantly the camera records at 30fps. I converted the file from MPEG2 to .mov via a HP laptop as my Mac wouldn't recognise the MPEG file and I hadn't had the chance to explore MPEG Streamclip (i'm new).
So, with all this in mind which DVCPRO HD setting, if any, would be best?
Jo
Michael Sacci
Re: Which DVCPRO HD setting to choose to convert a .mov file
on Dec 9, 2010 at 7:51:14 pm
is there a good reason to up rez this footage?
But you would want to keep the framerate the same as your footage.
