transfer files from card to FCP come in as Quicktime.mov
graham bull
on Nov 10, 2010 at 4:48:38 pm
New to HDV with FCP 6 and MacG5 w/o intel. Transferred clips from card to wife's MacBookPro (FCP 6), then took the external hard drive to my computer and began work with clips. 2 problems. The clips would not run in the timeline without interruption and a prompt indicating dropped frames. What do I do there?
And the clips came into FCP in the form of QT.mov. These are already compressed right? Can I work with them and later compress with, say, Compressor? Or can control the transfer process so I get files in some other uncompressed form?
Have noticed the external hard drive I'm using is USB wired. Should I employ firewire instead?
Tom Wolsky
Re: transfer files from card to FCP come in as Quicktime.mov
on Nov 10, 2010 at 5:29:20 pm
USB is not supported for use with video applications. You need a fast FireWire drive for this media.
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP7," "Basic Training for FCS" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
graham bull
on Nov 11, 2010 at 12:30:42 pm
thank you. i'm equally concerned about card files coming into fcp as qt.mov. can i control the format of transfered files off avchd card?
Tom Wolsky
on Nov 11, 2010 at 12:46:47 pm
AVCHD transfer in FCP requires an Intel machine. You can pick a number of different ProRes codecs to transcode your AVCHD media to.
All the best,
Tom
