How do I keep 16x9 footage constant in Timeline?
Travis Stewart
on Nov 9, 2010 at 4:08:23 am
I have set sequence settings at 16x9 for the footage I am editing. The first clip I bring in from my footage comes in fine, no rendering required and shows up in the Viewer as 16x9. But if I attempt to bring in a different clip later on in the footage, it wants to render it and doesn't want to show it in 16x9 (it has borders on the left and right instead, even after rendering). All these clips are coming from the same captured footage, and all of it is in widescreen. Is there a way to fix this? Thanks!
Tom Wolsky
Re: How do I keep 16x9 footage constant in Timeline?
on Nov 9, 2010 at 4:21:56 am
Check that the anamorphic flag is checked on for all the clips. You can select them all and set the anamorphic check if it's not set.
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP7," "Basic Training for FCS" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
Travis Stewart
on Nov 9, 2010 at 5:34:33 am
Thank you so very much, this solved the issue! Now onward with creativity :)
