Which codec to choose for a music video edit with this setup?
Simen Myrberget
on Oct 26, 2010 at 7:11:44 pm
I am using a new camera (for me that is) a Panasonic Hdc Sd700 and have shot a music video with two of these cameras. I am using Clipwrap to encode and the options as far as I can see are:
Apple Intermediate Codec (Aic)
Apple ProRes 422
Apple Prores 422 HQ.
I am going to use some effects so there will be several tracks of video to deal with. I have an external esata drive and another external FW800 drive.
I am working on a laptop (Macbook Pro) with these specs: 4 Gb Ram, 2.5 GHz Intel Core 2 Duo
Is 422 HQ to much to handle for this machine?
I still have much to learn ..... :-)
Andy George
Re: Which codec to choose for a music video edit with this setup?
on Oct 26, 2010 at 10:08:49 pm
Go Apple ProRes 422. The HQ version just steps it up from 8 bit to 10 bit. Since your not shooting over 8 bit it would just create a larger file with no gain in quality.
These will work nicely over an esata connection.
-Andy George
Senior Editor
http://www.chiselindustries.com
Michael Sacci
on Oct 27, 2010 at 5:49:14 pm
[Andy George] "The HQ version just steps it up from 8 bit to 10 bit. "
Andy - you need to stop saying this, it is not correct. ProRes HQ and ProRes are both 10-Bit. HQ should not be used when coming from other video codecs. There are documented issues with encoding and rendering HQ, it is really reserved for animation applications. ProRes for the rest of us, but ProRes IS 10-bit.
Andy George
on Oct 27, 2010 at 6:11:48 pm
Michael,
Thanks for pointing that out. I had some bad information there.
Always learning.
-Andy George
Senior Editor
Simen Myrberget
on Oct 27, 2010 at 8:33:09 pm
Thanks for the correction, but will my machine handle Prores (not HQ)?????
Michael Sacci
on Oct 27, 2010 at 8:39:52 pm
A lot easier to handle ProRes then ProRes HQ. You will need a FW800 drive, if you are using compositing (pulling more than one stream at a time) it would be wise to get one of the RAID0 enclosures.
Simen Myrberget
on Oct 27, 2010 at 8:45:54 pm
Thanks again. A RAID 0 enclosure? Does that mean an esata connected box with several drives chained as one drive? Is the point having one drive pr. video stream?
Simen Myrberget
on Oct 27, 2010 at 8:30:22 pm
Yes. Thanks for the answer :-)
