Exporting from FCP7 for vewing on a PC
Lara Taylor
on Oct 11, 2010 at 9:04:23 pm
I am trying to find out what the best way is, to export clips from my FCP7 timeline to be used on a PC.
How do I
a) export the clips and
b) burn these clips onto DVD so that my client can open them up as independent video clips?
Shane Ross
Re: Exporting from FCP7 for vewing on a PC
on Oct 11, 2010 at 9:30:46 pm
Export as H.264 files. Burn those onto a disk.
If you want to convert ALL of your source clips, just take the source files into COMPRESSOR and use the H.264 presets...QT7 I believe.
Shane
Lara Taylor
on Oct 12, 2010 at 6:21:08 am
Hi Shane
Thanks for the response. I'm a bit of a novice at all this so a few more questions if you have time:
- When I converted straight from FCP to H.264, before, the clips had lines running through them
- I'm not too au fait with Compressor, is it possible to give me a summary of how to go about it?
- Once the files are converted, can I simply burn them directly onto a disc or do I need to work through a programme like DVD Studio Pro?
- Finally, what is QT7 (quicktime)?
Thanks so much,
Lara
Shane Ross
on Oct 12, 2010 at 7:42:31 am
[Lara Taylor] "- When I converted straight from FCP to H.264, before, the clips had lines running through them"
How did you convert? Do you mean INTERLACING? If you shot an interlaced format, like 1080i...then you need to DEINTERLACE when you compress. Computers don't like playing back interlacing.
[Lara Taylor] "- I'm not too au fait with Compressor, is it possible to give me a summary of how to go about it? "
Open Compressor. Drag a clip you want to convert into the small box in the small window with the arrow pointing down on the upper left portion of Compressor. Then go into the SETTINGS and look for OTHER WORKFLOWS>WEB>Quicktime 7 compatible. Drag the one you want onto the grey bar that you just dragged your clip onto. That should deinterlace it by default...any of those settings.
[Lara Taylor] "- Once the files are converted, can I simply burn them directly onto a disc or do I need to work through a programme like DVD Studio Pro?"
Insert a blank DVD. Drag and drop onto the DVD...then open the DVD and click on the BURN option, or drag to the TRASH, that now looks like a radioactive icon.
[Lara Taylor] "- Finally, what is QT7 (quicktime)?"
Yes, QuickTime. That's the abbreviation. QT.
Shane
Lara Taylor
on Oct 12, 2010 at 8:39:33 am
Thanks so much Shane
I didn't film the footage but I know it was shot on DV Pal. When I clicked on de-interlace it seemed to work!
Lara Taylor
on Oct 13, 2010 at 9:23:36 am
Hi Shane,
Lara here again. Any idea why, when I burn the videos onto DVD, some of them get 'stuck'?
