correcting darkness around eyes
Ron Guilmette
on Oct 8, 2010 at 7:30:01 pm
What would be a way to fix some shadow problems due to a poor lighting
I have a guest speaker at a podium and the lights were positioned more on top of the person because he was leaning over the podium which created darkening around the eyes and facial features.
I tried to follow a tutorial here on CC on fixing exposer in 3 way color correction, but the version on FCP they were using was an older version so some of the steps I could not follow.So I could not get to the same result.
I just want to lighten up the dark areas with out effecting the rest of the frame.
I have the lastest version of FCP.
Rafael Amador
Re: correcting darkness around eyes
on Oct 9, 2010 at 1:10:42 am
Google "Final cut marcus plugins" or "Final Cut Haiku Face light".
Ron Guilmette
on Oct 12, 2010 at 12:38:37 pm
When I follow the directions to install the plugins the path is different when I try on my machine. I can not find final cut system support>plugins. Also how do I unzip the files on a Mac?
I am on a newer Imac.
Here are his directions.
Once downloaded the plug-ins need to be unzipped and put in the plug-ins folder (Library>Application Support>Final Cut Pro System Support>Plugins).
These plug-ins will appear with the Color Correction filters.
Thanks for your help.
© 2018 All Rights Reserved
