Can you edit in low-res and then reload hi-res?
Madeleine Domries
on Sep 18, 2010 at 5:09:04 am
I'm sure this is a stupid question that will make people's eyes roll in their heads, but I'm tired of reading all kinds of stuff that is just serving to confuse me more and more.
Program: Final Cut Express HD
Footage: .mov files from 5DMarkII
When I import these clips into my project and try to edit... the clips are so large that it takes forever to render just to look through the clips to cut them down. Is there a way to edit the footage with lower quality clips for speedy work and then reload the clips at full quality for pretty picture? If so, how? And, if so... can I do everything... cutting, effects, transitions, colour correction with the small files?
Someone suggested doing the rough draft in iMovie and importing to FCE? Seems silly.
I guess I'm asking how do I start work in FCE for effective, efficient, and safe editing?
Shane Ross
Re: Can you edit in low-res and then reload hi-res?
on Sep 18, 2010 at 5:29:57 am
Final Cut Express is VERY limited in what it can do. And iMovie and FCE don't really mix. You should invest in FCP. That will allow you to work offline then online later.
Couple tutorials for you:
Tapeless Workflow for FCP 7 Tutorial
http://library.creativecow.net/ross_shane/tapeless_online/1
Shane
