apple pro res 422
adam dewhirst
apple pro res 422
on Sep 14, 2010 at 4:31:14 am
i am about to capture hdv footage from my hdrfx1 to final cut pro. i was advised to use pro res and have narrowed my options to two :
* apple pro res 422 1440/1080 25p (field dominance : none)
or
* apple pro res 422 1440/1080 50i (field dominance : upper [odd])
could somebody please advise me which setting to use and perhaps why as i'm not sure why i would choose one rather than the other?
the bracketed information regarding field dominance seems to be the only difference i can see and i'm not even totally sure of its significance...
thanks
Rafael Amador
Re: apple pro res 422
on Sep 14, 2010 at 5:16:14 am
Hi Adam,
The first one is for when you have shot Interlaced, the second one is when yuou have shot Progressive.
rafael
http://www.nagavideo.com
Rafael Amador
on Sep 14, 2010 at 5:18:14 am
[Rafael Amador] "The first one is for when you have shot Interlaced, the second one is when yuou have shot Progressive.
rafael"
Sorry, is exactly the opposite:
- None: When you have shot Progressive.
- Upper First; when you shot Interlaced.
rafael
adam dewhirst
on Sep 14, 2010 at 5:21:50 am
thanks for your response,
how do i find out which one i've shot?
does the hdrfx1 shoot interlaced or progressive?
adam
Rafael Amador
on Sep 14, 2010 at 5:39:24 am
Hi Adam,
i don't know that camera, but for what I see in Googles, it seems that only records Interlaced.
rafael
adam dewhirst
on Sep 14, 2010 at 6:00:06 am
yes i think you've worked this out.
thanks for your time
adam
