Aftger Effects graphics look crunchy in FCP
Doug Normington
on Aug 16, 2010 at 3:03:52 pm
Hi, I am editing a project in Final Cut Pro. Standard Def DV 16:9. I have made some animations in Aftereffects with the composition settings of DV wide screen. When I output the animations as quicktime they look fine in the quicktime player. When I bring them into Final Cut Pro they look fine when I step through then frame by frame but when I render the sequence the edges of the font looks frayed.
I have tried field rendering. Non field rendering. different codecs. not sure how to crack this one.
thank you in advance.
Doug
Rafael Amador
Re: Aftger Effects graphics look crunchy in FCP
on Aug 16, 2010 at 4:13:21 pm
Hi Doug,
Change your sequence codec to something better than DV (DV50, 8/10b Unc, Prores), and you will see the difference.
Cheers,
rafael
http://www.nagavideo.com
Doug Normington
on Aug 16, 2010 at 4:34:15 pm
I have used prorez50 and 8 and 10 bit and it looks the same. Kind of frayed on the edges. The font is generated in aftereffects...
Doug Normington
NORMCO Multi-Media, Inc.
(608) 824-0999 Office
(608) 345-7579 Cel
Rafael Amador
on Aug 16, 2010 at 5:30:55 pm
Are you watching the canvas at 100% and fully rendered?
Did you tried to change the Alpha Channel of the graphics?
rafael
Chris Tompkins
on Aug 17, 2010 at 2:04:21 pm
Render your AE grfx DV50.
Drop ur DV footage into a DV50 Timeline.
Render.
View Ext. monitor.
Chris Tompkins
Video Atlanta
Rafael Amador
on Aug 17, 2010 at 2:38:14 pm
[Chris Tompkins] "Render your AE grfx DV50."
No Alpha channel.
rafael
Chris Tompkins
on Aug 17, 2010 at 8:47:07 pm
Did not see any mention of Alpha in original post...
Chris Tompkins
Video Atlanta
Rafael Amador
on Aug 18, 2010 at 1:30:41 am
[Chris Tompkins] "Did not see any mention of Alpha in original post..."
Well, when people talk about "Graphics", I imagine an Alpha channel.
rafael
Kai Cheong
on Aug 17, 2010 at 2:37:12 pm
I had a similar issue during edit today which involved Livetype. Maybe my solution would help your situation: check the AE Quicktime you've dragged into the browser. Scroll across to the field order column - what's listed there?
Oddly enough, even though I'd exported a 'no fields' Quicktime from Livetype, when it was brought into the browser, it was tagged as 'Upper (Odd)'. I changed that to 'none' and replaced the clip in the sequence - problem solved.
Kai
FCP Editor / Producer with Intuitive Films
http://kai-fcp-editor.blogspot.com
Now 'LIVE'! Check Out The Intuitive Films Blog @ http://intuitive-films.blogspot.com
At Intuitive Films, We Create: TV Commercials, Documentaries, Corporate Videos and Feature Films
Visit us @ http://www.intuitivefilms.com
MacBook Pro 2.4GHz | 4GB RAM | FCP 5.1.4 | Mac OS X 10.5.7
8-Core Intel Mac Pro 2.26GHz | 8GB RAM | FCP 6.0.6 | Mac OS X 10.5.6 | 3.0TB CalDigit VR | 2 x 24" Dell S2409W
