Audio Filters need reinstalled and general error message
Roman Bostick
on Aug 6, 2010 at 12:16:57 am
Working on a sequence on an IMAC in FCP 6.0.6 that came from a MacBook Pro using FCP 6.0.6
We have the same audio filters but upon opening the sequence in the imac, we get the need to reinstall audio filters - audiodistortion message.
When rendered, the red line stays and the beeping is heard in playback
I tried the Render for item playback, the redline disappeared but now i get a general error
Help...what else can i try? how do i reinstall audio filters? and why is some of the footage now not playing when rendered and creating general error?
thanks
John Fishback
Re: Audio Filters need reinstalled and general error message
on Aug 6, 2010 at 2:42:00 pm
I'm not sure about the general error or the apparent lack of filters. Maybe trashing prefs and repairing permissions will help. As for the beeping, that happens when FCP doesn't like the audio format. Always convert any audio to Linear PCM, 48kHz, 16 or 24 bit in an external editor before bringing it into FCP. You can use,Quicktime Pro, Soundtrack Pro, MPEG Streamclip or any other program that can convert audio.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
Roman Bostick
on Aug 6, 2010 at 6:47:18 pm
Thanks so much
The trashing seemed to work and then rendering audio for item level only - it's all working fine again
John Fishback
on Aug 6, 2010 at 7:28:42 pm
I'm glad it worked out.
John
