Faster Workflow For Long Form Vids on FCP
Kyle MacDonnell
on Jul 25, 2010 at 8:23:42 pm
Hey Guys,
I was going to wait until after I've finished my first FCP project, but I have time because FCP is hung up over this spot on my timeline it doesn't like. Here goes:
2.8Ghz i7 iMac w 8 Gb Ram
Firewire 800 HD's
Final Cut Pro 7.0.2
I did a 2 camera HD shoot of a stage show; = 5 hours of .mov/.mts files + a 3 hour .wav sound file. About 100 Gb of files.
It took days to turn this into Apple ProRess 422 & then it choked my system. I converted down to SD lossless, but this chokes also. Rendering takes forever. There are a couple of spots on my timeline that freeze up.
My question is How can I work faster?
Any help would be appreciated!
Chris Tompkins
Re: Faster Workflow For Long Form Vids on FCP
on Jul 25, 2010 at 10:43:04 pm
What are you shooting on?
What format are u capturing on the shoot?
Did you use "Log & Transfer" to ingest the material?
Chris Tompkins
Video Atlanta
Kyle MacDonnell
on Jul 26, 2010 at 3:43:47 am
I didn't "Log & Transfer". I shot .mov files on a T2i, 1080p @ 30fps & .mts on a Canon HF S100. The .mts files I first converted to H.264 using Adobe Media Encoder, but about 3 of the files crashed FCP, so I wound up using iSkysoft to convert to H.264, then I converted everything in Compressor to ProRes 422 LT. After I decided that HD might be too much for my setup, I down-converted to SD widescreen lossless QT in Media Encoder (this actually made the files much bigger)....................
Chris Tompkins
on Jul 26, 2010 at 1:14:11 pm
H.264 is NOT an editing codec. Don't convert to that for editing.
ProRres is a great way to go.
I would take your original mov files on a T2i, 1080p @ 30fps & .mts on a Canon HF S100 and run them thru compressor and convert all to one format. Whether that's HD or SD is up to you. If file size is an issue I would convert all to DV50 SD animorphic.
OR
Edit native w/ mov files from the T2i, 1080p @ 30fps and convert the mts to mov files 1080p @ 30fps
OR
But don't convert to H.264 and then to something else that's twice the compression.
Chris Tompkins
Video Atlanta
