How Can I Achieve This Transaction???
Dyce Jackson
on Jul 19, 2010 at 3:42:07 am
I am very new to video editing an FCP. I am doing a wedding video for a friend. I put a few clips together for the intro and added an additive dissolve. I loved the effect it achieved it was kind of a flash & burn effect. But when I rendered the clips, they just look like a plain cross dissolve. I refuse to use a plain dissolve after seeing it with the other effect.
I did a screen recording of it and uploaded it here:
I know the quality is horrible but I hope you get the idea. Can anyone tell me how to achieve this effect? Or know of a plugin that will do it?
Please Help
Sascha Engel
Re: How Can I Achieve This Transaction???
on Jul 19, 2010 at 8:51:21 am
One possibility could be, that when you rendered it, it limits the whites to 100%. Try once to go into the Timeline Preferences (Apple + '0') and set the Render Settings to "SuperWhite". Does that change the results?
Sascha
Sascha Engel
on Jul 19, 2010 at 8:54:24 am
Can you please also post a screen shot of the rendered version you did not like?
Thanx.
Sascha
Mark Suszko
on Jul 19, 2010 at 1:49:15 pm
Or you could just put in 15 frames of white, and then put 10-frame dissolves on either side of it....
Thax Clave
on Jul 19, 2010 at 2:06:58 pm
[Mark Suszko] "Or you could just put in 15 frames of white, and then put 10-frame dissolves on either side of it....
That can (basically) be achieved using a single transition called "Dip to Color Dissolve" (make the color white.)
Thomas Morter-Laing
on Jul 22, 2010 at 1:01:45 pm
Or a flash transition and use the transition parameters to reduce the maximum exposure...
:D
Tom Morter-Laing
Certified Apple Product Proffessional, 2010
Production Assistant, Grace Productions
Degree; TV Production
