Sequence settings of AVCHD and HDV on same timeline
Paul Witcher
on Jul 15, 2010 at 3:01:47 pm
Hi guys,
I just wanted to run this by you guys to make sure all will be OK. I'm capturing my HDV as ProRes 422, in the browser checking the items props show 1440x1080 Apple ProRes 422. I have also AVCHD footage, checking the item props show 1920x1080 Apple ProRes (although I tranfered at 1440x1080) Popping the clips on the time line both sequence settings are 1440x1080 Apple ProRes.
What I'm I losing from the AVCHD footage (if anything) 1920x1080
Paul
Shane Ross
Re: Sequence settings of AVCHD and HDV on same timeline
on Jul 15, 2010 at 8:19:34 pm
Don't use the 1440x1080 timeline settings, use the full raster 1920x1080. Keep all the resolution of the AVCHD...FCP will stretch out the HDV/ProRes to match.
Shane
