advice after effects to final cut
marise nazzaro
on Jul 6, 2010 at 7:55:49 pm
I am new to after effects and when I import files that have been converted to .mov from after effects, I get the warning - dropped frames message. I don't have the drop down in final cut to turn off unlimited rt, I am not sure how to lower my compression data rate and I know my system is fine. Does anyone have any suggestions?
Todd Gillespie
Re: advice after effects to final cut
on Jul 7, 2010 at 5:08:46 pm
It sounds like After Effects is exporting out using the Animation codec?
You'll need to check to make sure the codec that you are editing with is the same codec you render out of After Effects.
Good Luck,
Todd at UCSB
Television Production
marise nazzaro
on Jul 7, 2010 at 5:59:12 pm
Thanks Todd. It turned out I had the wrong format size. I was using 1440x1280 and for whatever reason it worked 1280x720? Go figure?
