work whith hd in sd sequence
rui carvalho
on Jun 19, 2010 at 9:56:22 am
I have my footage in hd but i have to edit in a sd timeline, my question is, my hd is upper filde first then my sd sequence as to be upper fild firts right?? So far so good but when i export the movie and burn to a dvd to see in tv, it flic on tv why is that?? tanks
PPX
Rafael Amador
Re: work whith hd in sd sequence
on Jun 19, 2010 at 10:25:49 am
[rui carvalho] "I have my footage in hd but i have to edit in a sd timeline, my question is, my hd is upper filde first then my sd sequence as to be upper fild firts right?"
Right.
MPEG-2 can be Lower or Upper.
You need to make sure that Compressor understand the Field Order.
In the Inspector > Video Format, check "Upper first".
In the "Frame Control", set Output Fields > Same as Source.
rafael
http://www.nagavideo.com
