 | Audio in FCP
on May 27, 2010 at 12:19:53 am |
I am using FCP 7 and I shoot with AVCHD. After I log and transfer the clips into FCP they all have the "stereo pair" checked. I dont have independant control over the audio with it checked. Is there a way to get the clips to come in without the stereo pair? Also is there a way for FCP to have a mixed mono output?
thanks
Randy
Randy Johnson
Rando1968@comcast.net
 | Re: Audio in FCP on May 27, 2010 at 3:35:40 am |
Simple click the stereo pair and the link will be broken, then pan both channels to the center and it mixes the mono.
 | Re: Audio in FCP on May 27, 2010 at 3:48:29 pm |
o.k. cool thanks. I got this to work on a "per clip" basis. is there a way to make a "global change"? So everytime I bring in a clip it will have the stereo pair unchecked and come out mixed?
Randy Johnson
 | Re: Audio in FCP on May 27, 2010 at 7:51:31 pm |
I've never worked with AVCHD, but with other formats in L&T in the Import Settings tab next to the audio select buttons you'll see a symbol. Clicking it will designate the transferred audio as stereo or mono.
A way of dealing with this if you have a lot of clips already in a sequence is to change the audio of the first clip to the way you want it, then copy it (Cmd-C), select all the following clips and Paste Attributes (Opt-V) and in the audio choices check Levels & Pans, click OL and the change will be applied.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
 | Re: Audio in FCP on May 28, 2010 at 3:28:06 am |
Nice! thanks John I think that will work. Unfortunatly when I use the log and transfer tool with my raw theres only one audio option basicly audio or not and it says audio will be imported in stereo.
Randy Johnson
