Another Question about Importing footage from Canon VIXIA HV40?
Patricia Snyder
on May 26, 2010 at 3:52:33 am
I followed Steve Tanguy's advice about importing HDV footage and it worked like a charm. However, I need to import SD footage and once again FCP isn't recognizing the device. What are my settings for SD?
Sascha Engel
Re: Another Question about Importing footage from Canon VIXIA HV40?
on Jun 1, 2010 at 10:04:59 am
Could be many things: start from scratch:
Shut down Computer, connect your DV Device - start up again - after you opened press "Check A/V Devices" in FCP.
Open the Log & Capture window (Command "8") -> in there make sure that under the Capture Settings Tab -> you are set to FireWire PAL (if you are in PAL land).
Does it recognize your device then?
Sascha
