How do I achieve this?
Charlee Núñez
on May 13, 2010 at 2:40:07 pm
I want the final frame of my short film to be paused (a freeze frame if you will), then slowly fade to black.
Thanks in advance!
David Battistella
Re: How do I achieve this?
on May 13, 2010 at 3:00:04 pm
Pick the frame you want to freeze on.
Hit match frame or hit the f key.
Go to the MODIFY menu and select MAKE FREEZE FRAME
overwrite edit the freeze frame at the same place in the timeline ( 2 seconds maybe)
Add the dissolve to the freeze frame.
David
Peace
Mark Suszko
on May 13, 2010 at 3:00:42 pm
Top of your screen, in the drop-down menus, Modify>Freeze frame. In the left hand canvas, upper left numerical box, type in a duration, say, 30 frames. Hit "Enter". Now you can drag and drop that still onto the timeline right next to the last frame, and apply a dissolve to black. Stretch the lengths of the dissolve adn the freeze frame piece to taste. I usually put a slug of black next to the last shot to dissolve to.
Charlee Núñez
on May 13, 2010 at 3:55:57 pm
Awesome! Thanks, guys.
Sascha Engel
on May 18, 2010 at 3:39:40 pm
just make sure, your footage is progressive - if not, make that part first progressive by De-Interlacing, then do what's mentioned above. If not, you will freeze frame a picture with Interlaced lines.
Charlee Núñez
on May 20, 2010 at 12:30:53 pm
Thanks for the tip!
