tvc requirement
Dan Newton
tvc requirement
on Apr 3, 2012 at 10:34:24 am
hi
need some help
I was asked by a client to convert a mov to the following format:
MPEG TYPE: H.264 MAIN
STREAM TYPE: TRANSPORT ( VIDEO )
VIDEO MODE: PAL
CONSTANT BIT RATE: 1900 KBPS
FRAME RATE: 25 FPS
RESOLUTION: 720 X 576
SAMPLE RATE: 48 KHZ
BITRATE: 224 KBPS
STREAM TYPE: TRANSPORT AUDIO
AUDIO TYPE: MPEG LAYER 2
MODE: STEREO
Please can someone help me I am quite confused on some of the settings on when I go on to compressor it keeps giving me something different can someone help me/ guide me step by step on what I need to do.
Your help is appreciated.
Many Thanks
Rafael Amador
Re: tvc requirement
on Apr 4, 2012 at 11:32:00 am
I don't think you can do that with Compressor.
If I'm not wrong, the only Transport Streams that Compressor can do are with MPEG-1/MPEG-2 video, but not with H264.
rafael
http://www.nagavideo.com
Rafael Amador
Re: tvc requirement
on Apr 4, 2012 at 11:36:52 am
I've found this old thread on the same subject:
http://forums.creativecow.net/thread/20/860107
rafael
