When should I choose DV-NTSC Anamorphic for capture?
Dan Spezz
on Apr 26, 2010 at 12:02:05 am
If I set my DV cams to record widescreen 16:9, do I need to select the DV-NTSC Anamorphic capture setting, or is that setting used only for taking standard 4:3 footage and making it widescreen aspect ratio?
David Battistella
Re: When should I choose DV-NTSC Anamorphic for capture?
on Apr 26, 2010 at 3:44:39 am
You could set it to anamorphic on capture or you could just check the checkbox in the file browser after the fact as well.
david
Peace
