working with different format
michal yaniv
on Apr 25, 2010 at 11:46:11 am
I need to know the correct work flow in a project with 2 different format, which is: DV-PAL 720*576 25fps and HD XDcam 1920*1080i50 25fps
Some say that I have to convert everything to prorez befor start editing. some say - don't convert.
what kind of sequence setting I should use?
should I export everything as PAL or HD?
The end product should be a 50 min movie, on a regular DVD (for home use).
So many questions....
I'll be happy to know the correct work flow for projects like this.
Thanx,
Michal
Michal Yaniv
http://www.avocadofilms.info
John Fishback
Re: working with different format
on Apr 25, 2010 at 3:31:23 pm
You've got two very different formats. My suggestion is to edit in HD and uprez the DV footage using Compressor. There's plenty of discussions how to do that if you search the Cow. I've never edited with XDCAM before so I don't know the recommended workflow.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
michal yaniv
on Apr 25, 2010 at 3:45:09 pm
Hi John,
thank you for your quick answer.
I know those are 2 complitly different formats, and actually I believe that this is how hell looks...
anyway, if I want to uprez the DV stuff with compressor, do you know the setting I should use?
Michal
Michal Yaniv
John Fishback
on Apr 25, 2010 at 5:02:40 pm
Checkout this thread. You'll find more info if you search for uprez HD or similar.
John
michal yaniv
on Apr 25, 2010 at 6:14:07 pm
Hi John,
thanx again.
it was useful
Michal
Michal Yaniv
