GFX render
Anne Holst
GFX render
on Apr 23, 2010 at 3:57:34 pm
I'm having a huge problem with graphics in Final Cut.
Every time I import some kind of graphical text, it pixelates. Whether it being a still with an alpha channel or a quicktime movie with text. The weird thing is, when I render it, it become even worse.
Have any of you had the same problem?
Please help!
Anne.
walter biscardi
Re: GFX render
on Apr 23, 2010 at 4:00:47 pm
Have you reviewed this to ensure you're monitoring your project properly?
http://forums.creativecow.net/faq/applefinalcutpro#59
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media
"Foul Water, Fiery Serpent" featuring Sigourney Weaver coming soon.
Blog Twitter Facebook
Anne Holst
Re: GFX render
on Apr 23, 2010 at 4:10:35 pm
I haven't got a broadcast monitor, but here is what happens:
I have a nice sharp QT from graphics. It plays beautifully in QT player. I import it into FP, put it on a timeline (DV Pal anamorphic) and export as another quicktime and it with current settings. And it look s horrible when I play it back in QT... Don't know what to do...
Shane Ross
Re: GFX render
on Apr 24, 2010 at 1:38:16 am
It's the DV codec. It makes the graphics look bad. You can export them as uncompressed, or using the Animation codec, but when you drop them into a DV timeline, BAM, they inherit the DV compression. 5:1 compression, 4:1:1 color space...jaggies...the works!
If you want your graphics to shine, don't use a DV sequence. Use a DV50 or ProRes NTSC.
Shane
