nesting sequences and audio problem
Eric Holzapfel
on Apr 22, 2010 at 4:45:17 pm
Hello Forum Members,
I think my question is somewhat basic.
I have several sequences with various audio tracks. I want to
put each sequence in a "master" sequence. So far this has worked fine.
I have one sequence that has 12 audio tracks. The audio levels, etc
are fine when I play the sequence in the view/timeline. When I drag the sequence into the master sequence, the audio plays fine up to a point, and then the level cuts down alot, and then returns to the correct level.
I have tried raising the level in the "child" sequence, but that seems not the way to do things. Any tips or suggestions on how to get the audio to play correctly in the sequence where I nest it? The audio tracks are aif tracks, etc.
Eric
John Fishback
Re: nesting sequences and audio problem
on Apr 22, 2010 at 7:15:39 pm
Try doing what FCP calls a Mixdown: Sequence Menu > Render Only > Mixdown
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
Eric Holzapfel
on Apr 22, 2010 at 8:41:52 pm
Hello John,
I will do that. Thanks.
Eric
