Sequence settings
Ryan Vaugh
Sequence settings
on Mar 19, 2010 at 9:01:25 pm
I am doing story board animatics using FCP. I am receiving jpegs that are 1920x1080. I have to do 24fps because of a handoff to a storyboard program. I am having trouble finding a sequence setting to use that allows my to add zooms on panels without requiring rendering. Right now I am using Apple Pro Res 422 (HQ), 24fps,48k, 24bit, aspect ratio square. I am on a Dual 2 Ghz PowerPC G5, 10G ram. My timeline plays but with green render bar and once I add zooms it needs to be rendered to play properly. I have have adjusted my Rt settings and play base level only with little noticeable change.
Any help would be great.
Rob Grauert
Re: Sequence settings
on Mar 20, 2010 at 2:09:10 pm
I think adding motion to still images ALWAYS requires rendering. that's just how it is.
I don't think you need ProRes HQ though - regular ProRes will be fine.
I doubt you need 24-bit audio either. Unless the audio you are using already is 24-bit, 16-bit is fine.
Robert J. Grauert, Jr.
http://www.robgrauert.com
command-r.tumblr.com
Ryan Vaugh
on Mar 20, 2010 at 8:35:21 pm
Thanks for the reply. Here is another quick question. I have my Seq. Settings at 24fps , but when I look at the clip info of any of the jpegs they are at 29.97. Why is that?
Thanks again
