can't export piece of clip
Aysu Grodowski
on Mar 16, 2010 at 11:16:16 pm
I finished my piece and set the in and out on my timeline, but when I try to export to quicktime movie it keeps cutting out at a certain point about 2 minutes before the piece ends. I even tried extending the out marker further and it still cuts out at the same place. Everything's rendered, it plays perfectly fine on my timeline...What's wrong?
John Fishback
Re: can't export piece of clip
on Mar 19, 2010 at 3:12:00 pm
Have you trashed prefs and repaired permissions? Also, running Disk Warrior might help. It will help folks help you if you tell us what computer, OS, version FCP, type of drives used for capture, etc.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
