image output problem
Dan Newton
on Mar 12, 2010 at 8:09:11 am
I have a small problem ---
i have an image that i converted to PNG FORMAT
Now when i move the image from left to right -- when i output the image the image looks all shaky --- why is that ---
I even tried in after effects and the same thing happens ---
Please Help?????
Shane Ross
Re: image output problem
on Mar 13, 2010 at 1:10:11 am
Deinterlace it. Either before you export it, or after, with Photoshop or similar.
Shane
Dan Newton
on Mar 13, 2010 at 10:47:04 am
Thanks for getting back to me --
If I interlace it in Final Cut --- what should it be --
1. UPPER ( ODD )
2. LOWER ( EVEN )
3. FLICKER FILTER ( MINIMAL )
4. FLICKER FILTER ( MEDIUM )
5. FLICKER FILTER ( MAX )
Kind Regards,
Dan
Rafael Amador
on Mar 13, 2010 at 12:04:23 pm
If is a video frame that you have exported as PNG and your footage is interlaced, you need to de-interlace it before exporting.
If is an still or graphic that supposed to be Progressive, check it as Field Order NONE in the Browser and lie it again in the sequence.
Rafael
http://www.nagavideo.com
