Why does render mov sometimes get split into pieces, *.mov1, *-av.mov2, *-av.mov3...?
Naiche Lujan
on Mar 2, 2010 at 8:58:34 pm
It's only happened a couple times, but does anyone know why FCP would output an mov in parts? For example, I export the timeline as self-contained file(not reference) and instead of a single *.mov(ProRes), I get a couple mov's named like so:
filename.mov
filename-av.mov1
filename-av.mov2
(I'm not in front of the files at the moment, the -av part might also be sequential as in -av1, -av2, etc.)
I'm thinking it might have to do with the file system on the destination drive, or a setting that got changed somehow. I can give more information if there is not enough here, just thought it might be something simple.
Tom Wolsky
Re: Why does render mov sometimes get split into pieces, *.mov1, *-av.mov2, *-av.mov3...?
on Mar 2, 2010 at 9:44:32 pm
Either the drive is not correctly formatted as Mac OS Extended or the limit export size function is switched on on System Settings.
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP7," "Basic Training for FCS" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
