Editing Nikon D3S video material with FCP 5.1.4
Emil Herrera-Schulz
on Mar 1, 2010 at 2:17:32 pm
Happy 1st of March!
I need some help with video material I have started editing within FCP 5.1.4.
I am not sure what are the best settings for my sequence in order to properly work with the AVI files that come from my Nikon D3S.
Accidentally the other day I changed the settings on FCP. Under Audio/Video Settings and now it is:
Sequence Preset: Apple Intermidiate Codec (I have never worked with this one before)
I assume I should change it to something like HDV - 1080i50
But my files didn't come from a HDV, and if they all are AVI, what preset should I use?
Under "Sequence Settings" I find my self lost again. I cannot find anything similar to the settings of my original files (which are 1280 X 720 to start with)
For example, when I imported video form the D3S and placed it on my timeline, the image on the preview screen appeared smaller, so I had to pull the corners to fill the frame. Clearly I am doing something wrong.
Then when I try exporting with Compressor, it always fails to export or it says codec error.
What can I do?
Thank you so much!
Emil
Richard Harrington
Re: Editing Nikon D3S video material with FCP 5.1.4
on Mar 1, 2010 at 8:39:11 pm
Transcode with Compressor to AIC 720. Use advanced format conversion presets. Match sequence settings to transcode
Emil Herrera-Schulz
on Mar 2, 2010 at 8:48:24 am
Hello Richard,
I don't know how to transcode using AIC, but I have started reading Compressor's manual and might be able to figure it out. If not, will ask again :) I think this is not available in my FCP 5.1.4 version.
I think that if I upgrade to FCP7 or FCStudio 3 might make my life easier. Do you know if I can upgrade to 3 if I have version 1?
Or do I have to upgrade first to FCSutido 2?
Thank you!
Emil Herrera-Schulz
http://www.visionsofthewild.com
