Export for Blue-Ray
Brett Nolan
Export for Blue-Ray
on Feb 9, 2010 at 8:26:10 pm
Hey all,...We have a 1080-60i Final Cut Express project that we want to export with minimal loss for transfer to PC for use in Sony Vegas. We would like to keep the 1440x1080 size and maintain minimal loss (who doesn't, ...I know). Any suggestions, recipes?
Put simply,...I suppose, what are the generic blue-ray export settings?
thanks
B.Nolan
http://www.awenmediadesign.com
Rafael Amador
Re: Export for Blue-Ray
on Feb 10, 2010 at 4:44:12 am
Hi Bret,
BR works with H264 and MPEG-2, but with certain specs.
You will need an application with the correct presets to export.
I guess you don't have Compressor.
Try to export with the higher quality that FC Express allows.
rafael
http://www.nagavideo.com
Brett Nolan
on Feb 10, 2010 at 4:07:40 pm
Thank you for your response, I have access to compressor. I just want to turn the clips into a self-contained movie without changing the 1440x1080, etc. Even a 20G file would be fine as long as it would play in Windows.
Would exporting it at "default settings" keep it's native format?
B.Nolan
Rafael Amador
on Feb 10, 2010 at 5:43:02 pm
Export directly a QT Movie from the time-line.
Will keep the setting of your sequence.
rafael
Greg Barringer
on Feb 13, 2010 at 7:38:27 pm
As Rafael said export as a Quick Time Movie, not a QT conversion. I'm assuming you want to take this into DVD Architect and burn BD, is that correct?
